This message indicates that the client ISC application has not been found. In such a case, CM's MLAG mode functionality will not function properly.
This is a rare condition which may be related to software, and may require a reboot of the switch to correct the problem. If it persists, contact technical support and provide outputs of 'show switch', 'show log'.
Error
Client ISC application data not found %isc%
| Name | Type |
| isc | uInt16 |
